Latest post Tue, Dec 13 2011 11:49 PM by David Yardley. 17 replies.
Page 2 of 2 (18 items) < Previous 1 2
  • Thu, Nov 17 2011 2:31 PM In reply to
    • David Yardley
    • Joined on Fri, Mar 3 2006
    • Darkest Kent UK
    • Posts 729
    • Points 8,610
    Re: Older Mac Pro system Qualified question
    Actually I am today using a 1.1 Macpro with MC 6 and it is working a lot better than it did with MC5.5.3- No dropped frames with P2 footage, RGB output and DVI to the Panny from the Aja IO express, and  Pglue error almost disappeared.
    The Trusty Adrenaline is now permanently pressed into service as an SDI audio disembedder!
    Thank you Avid team.
    MC 5.53/6.0.3.2 and Symphony 6..0.3.2 OS 10.7.2 QT 7.6.3 Aja Kona 3, Aja I/O express Mac Pro 2x2.66 6-core 14GB Ram Apple 4GB Fibrecard Infotrend 2x 16TB... [view my complete system specs]
  • Tue, Dec 13 2011 10:53 PM In reply to
    Hi all.  So, I'm unclear as to whether this works or not.  I am working with an editor now and he has a MacPro (version1,1) 2.66 GHz Dual-Core Intel Xeon processor with plenty of RAM.  We tried to install Avid 6.0, but got the error about not being able to access the 64-bit kernal.  Can someone please tell me definitively if there is an answer to this? I am quite confused.
  • Tue, Dec 13 2011 11:49 PM In reply to
    • David Yardley
    • Darkest Kent UK
    • Posts 729
    • Points 8,610
    My 1,1 Mac pro 2x dual core 3GHz 7GB Ram (as below) works OK with MC 6. It has 32bit EFI and cannot boot into a 64 Kernel. I get dropped frames if I run in 10bit mode with P2 Intra100 footage. Green (8bit) is just about OK until it hits a real time dissolve. Yellow/Green is fine.
    I suspect a less demanding codec like DNxHD or uncompressed would be fine.
    I would say it is running as well as it did with MC 5.53.
    I am still getting occasional PGlue errors (as I did in 5.53) but I think this is corrupt audio media.
Avid Technology, Inc. brands:
M-Audio  |   Sibelius  |   Pinnacle Systems  |
