Latest post Sat, Jun 9 2012 10:42 PM by Tom Pearson. 29 replies.
Page 2 of 2 (30 items) < Previous 1 2
  • Tue, Jun 5 2012 8:33 PM In reply to
    • tawlif
    • VA
    • Posts 136
    • Points 1,570
    Re: Panasonic AF100 AMA workflow
    Thx Todd, mjolnarn i'll try that tonight
    MacPro Dual 2.8GHz Xeon (Quad-core) Harpertown 14Gb MacOS 10.7.5 Media Composer/Symphony 7.0 [view my complete system specs]
  • Tue, Jun 5 2012 8:54 PM In reply to
    • jdcoletv
    • Joined on Tue, Aug 16 2011
    • Posts 83
    • Points 995
    I second using Clipwrap. Works great and is pretty speedy. I find AMA while speedy upfront, you pay with transcoding and export time on the backend. No free lunch, as they say.
    MacBook Pro (15-inch, 2017) running with 16gb and Sierra (10.12.6), Radeon Pro 560 4096 MB. [view my complete system specs]
    Regards,
    Jeremy
  • Tue, Jun 5 2012 8:59 PM In reply to
    How do you pay later on exporting?  Transcoding you pay for obviously, but you get that time back at the end when everything is native DNX right?  Exports are lightning fast.... SAS.
    I disagree.... For the AF-100..... AMA.... transcode..... edit.  Quickest and smoothest way to Rome IMHO.
    MC 2018.9, Blackmagic UltraStudio 4K, 12-Core MacPro, 64 GB RAM, 24 TB Thunderbolt Storage [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc
  • Wed, Jun 6 2012 5:00 AM In reply to
    • tawlif
    • VA
    • Posts 136
    • Points 1,570
    Todd Sanderson:
    Hi again,
    When i tried to "Link AMA Volume" my system needed to download the AMA plugins.
    After installing the plugin, Symphony just loaded everything to bin.
    the million $ question is:
    Should I consolidate the footage or i can just edit using the media in that bin???
    (frankly your last comment Todd confused me)
  • Wed, Jun 6 2012 5:49 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    tawlif:
    Great
    tawlif:
    Not consolidate, as Todd says
    Todd Sanderson:
    tawlif:
    Yes, for lighter projects that is possible, a transcode might be needed at the end before exporting it out
    Tomas
  • Wed, Jun 6 2012 2:09 PM In reply to
    I suggest you transcode to your desired resolution right away.... prior to any editing.  You'll be happy you did later when you want to export rough cuts, etc, etc.
    I've gotten in the habit of AMA'ing my footage and setting up transcodes overnight, so there's very little down time.
  • Thu, Jun 7 2012 2:05 AM In reply to
    • tawlif
    • VA
    • Posts 136
    • Points 1,570
    Yes i got it now thank you...
    Any recommanded resolution to be used?
    Like is 1-1 too much?
  • Thu, Jun 7 2012 5:38 AM In reply to
    ok, just to expand, please help me understand when AMA-transcode is necessary...from this reference: AMA workflow questions
    Todd Sanderson:
    Ervz Tia | Video Productions
    Filed under: ,
  • Thu, Jun 7 2012 5:40 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 159,335
    tawlif:
    I suppose that you are using Ntsc media and, if so , transcoding codec to be used would be DNxHD 145 or 220 / 220 x .
    Resolution to be used is the same as your source media, I guess 1920 x 1080
    Tomas
  • Thu, Jun 7 2012 2:43 PM In reply to
    Hi Tikboy,
    It's necessary for many reasions.  if you can't play back certain AMA formats smoothly.  5D files for instance are just unable to play back for me without stuttering.  So I transcode first.  Also, when you export your sequence you may get messages that say you need to consolidate prior to export.... depending on your desired export format.  In my situation, when I'm exporting, I'm typically out of time.... so this is not a good situation for me.  Thus, I transcode 'everything' to DNX145 prior to any editing.  However, you 'can' just edit with the AMA footage and then consolidate at the end.  This is good as it saves time and space up front.  Particularly on large projects, this can be a huge space saver and time saver up front.
  • Fri, Jun 8 2012 3:57 AM In reply to
    • tawlif
    • VA
    • Posts 136
    • Points 1,570
    mjolnarn:
    But i do not have: DNxHD 145 or 220 / 220 x .
    following are the available ones:
    AVC-Intra 100 MXF
    DNxHD 36 MXF
    DNxHD 115 MXF
    DNxHD 175 MXF
    DNxHD 175 X MXF
    Apple ProRez MXF
    Apple ProRez HQ MXF
    Apple ProRez LT MXF
    Apple ProRez Proxy MXF
  • Fri, Jun 8 2012 5:35 AM In reply to
    The available resolutons are dependant on the project type.  In the built-in HELP, see:
    Resolution Specifications: HD
    (wwld)
  • Sat, Jun 9 2012 2:54 AM In reply to
    • tawlif
    • VA
    • Posts 136
    • Points 1,570
    Thx again Randall,
    i was hoping to find an easier/direct explanation or direction like: "wich one is 1 to 1 or 2 to 1?"
    or if there was any common recommended one, like for offlining use:
    "Avid DNxHD 36, a screening-quality HD offline resolution for progressive formats"
  • Sat, Jun 9 2012 9:45 PM In reply to
    I'm editing this promo from a AF100 through AMA. It works, barely. Since it's only a short taster tape, I tried editing this on AMA. I felt it was really slow. even for my Matrox bugs standard, It's down to unusable.
    So, today, just because I am finishing it, I tried this on Premiere CS5.5.
    It's ridicusly faster. It's like I bought a 4 times faster Mac Pro. Realtime, really. No import. Unbelievable.
    I don't know what Avid is doing with it's 64 bit prowess, but maybe they need to hire some adobe engineers. And the funny thing is that my processors are a lot less used under Premiere. What's going on? I heard AMA relied a lot on RAM... is that the problem? I have only 14 gb which seems to be enough for Adobe.
    Anyway, enough of whining, I just want the NLE I love to be on par with what's expected of our computers these days.
    Mac Pro 8 core 2.4 Ghz (Middle 2010), 14 Gbs RAM, Matrox MXO2 Mini, GTX970 OSX v.10.10.1 AVID MC 8.3.1 [view my complete system specs]
  • Sat, Jun 9 2012 10:42 PM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Minneapolis MN
    • Posts 2,165
    • Points 23,235
    Im just finishing my second film shot on that same camera  and Todd is dead right check your footage in ama then transcode dont mess with editing in ama... you will be so much happer especialy after you add a couple of cross fade's and fx's  and we wont even get into trying to color correct with ama
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
