Latest post Sat, Jun 9 2012 10:42 PM by Tom Pearson. 29 replies.
Page 1 of 2 (30 items) 1 2 Next >
  • Tue, Sep 27 2011 6:03 PM
    • Brian Mills
    • Joined on Tue, Jan 27 2009
    • Media Production Group
    • Posts 80
    • Points 880
    Panasonic AF100 AMA workflow
    I just want to confirm that there is no way to work with the files from this camera with MC 5.5.3 nativly AMA import...one has to import these files the old fasion way?
    Brian
    Avid MC 8.4.3 HP Z820 Intel Xeon E5-2650 16GB memory, Nvidia Quatro k4000 Win 7 Prof 64 Matrox [view my complete system specs]
  • Tue, Sep 27 2011 6:18 PM In reply to
    Re: Panasonic AF100 AMA workflow
    this camera works with the AVCHD format... so you are right, until now in MC 5, you can only import it the old fashion (and slow ) way... no AMA yet.
    Social Media Manager at Avid
    Editor-in-Chief avidblogs.com
    Got a great story to tell for #TimelineTuesday?
    Want to share a Media Composer Tutorial on #TutorialThursday?
    Contact me!
    Twitter: @editorbelga
    Facebook: fb.com/editorbelga
  • Tue, Sep 27 2011 6:49 PM In reply to
    • Brian Mills
    • Posts 80
    • Points 880
    Thanks for the confirmation.  I hope they are working on an update that supports it.  BTW does the panasonic converter that they took off there website just rewrap the files or does it actualy compress them further when converting fles to P2?
  • Tue, Sep 27 2011 7:08 PM In reply to
    Currently the best method is a direct import.  Anything else is a waste of time and does not improve image quality.
    MC 2018.9, Blackmagic UltraStudio 4K, 12-Core MacPro, 64 GB RAM, 24 TB Thunderbolt Storage [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc
  • Tue, Sep 27 2011 8:59 PM In reply to
    • Brian Mills
    • Posts 80
    • Points 880
    Does this work with spanned clips let?  I got an error wehn trying to import a spanned clip...im using MC 5.5.3
  • Fri, Sep 30 2011 6:35 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    Not yet.
  • Mon, Oct 24 2011 2:05 PM In reply to
    • Allan
    • Denmark
    • Posts 291
    • Points 3,545
    AVCHD Spanned clips.
    It is well known spanned clips take enormous time to import/ingest
    How big or long must a take be before it will span?
    It would be useful to know how to avoid them.
    We a are all looking for MC 6.0  With workflows spanning from AVCHD to RED. Rumours from IBC
    13 edit stations Educational MC 6.5.2 in use, MC 6.5.3 under reliability test, MC 7 under consideration workflow test, dongles with troubles, AVID ISIS... [view my complete system specs]
  • Wed, Oct 26 2011 8:03 AM In reply to
    • hbrock
    • Santa Monica, CA
    • Posts 5,520
    • Points 64,055
      Moderator: MCA Mac
    Generally 4GB is the max file size for a FAT32 clip.  The bit rate of the codec will determine how much material you can record in a 4GB file.  Until you can do some research, figure about 12 minutes or less until the clip spans over to another file.  Your actual mileage may vary...
  • Wed, Oct 26 2011 5:20 PM In reply to
    Our experience with the AF-100 is anything over 15 minutes will span.  I have the camera guys stop during long interviews during a question every 15 minutes or so to start a fresh new file.  This has worked for us thus far.
  • Sat, Oct 29 2011 1:13 PM In reply to
    • Eugene Huo
    • Joined on Sat, Oct 29 2011
    • Toronto
    • Posts 1
    • Points 15
    I've been using a program called clipwrap to import my large spanned clips, it creates a single file and transcodes to ProRes or various DNxHD.
    Not sure if that would help, just thought I'd suggest it.
    Sometimes its nice not to have to stop recording! Smile
    MacBook Pro "Core 2 Duo" 2.16 15" / Apple Mac Pro "Eight Core" 2.26 (2009/Nehalem) [view my complete system specs]
  • Tue, Jun 5 2012 3:06 PM In reply to
    • tawlif
    • VA
    • Posts 136
    • Points 1,570
    Any update on this subject please??
    MacPro Dual 2.8GHz Xeon (Quad-core) Harpertown 14Gb MacOS 10.7.5 Media Composer/Symphony 7.0 [view my complete system specs]
  • Tue, Jun 5 2012 3:19 PM In reply to
    MC v6.0.  Link via AMA.  Transcode.  Significantly faster than importing.  Should automatically mege physical spanned clips into a single Master Clip.
    (wwld)
  • Tue, Jun 5 2012 6:10 PM In reply to
    • tawlif
    • VA
    • Posts 136
    • Points 1,570
    Randall L Rike:
    thx Randal for your reply...
    can you plz elaborate more? the footage received are on an external HD (not in Cam) with a weird structure,
    where to go from there!!
  • Tue, Jun 5 2012 7:46 PM In reply to
    Hi tawliff..... link right to the .mts files.  Everything else can be ignored.  The same files you used to import, you now link to.
    ~T
  • Tue, Jun 5 2012 7:59 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 159,335
    or, if it is an origin untouched camera file structure, use link to volume and link to the main folder
    Tomas
