Latest post Sat, Sep 24 2011 1:04 AM by RobertoMFS. 10 replies.
Page 1 of 1 (11 items)
  • Sun, Sep 18 2011 10:08 PM
    • RobertoMFS
    • Joined on Thu, Mar 2 2006
    • Some PlAce IN the world
    • Posts 78
    • Points 1,040
    Problem With Mediaengine 5.1.3 & Mediarray LP (Solved)
    Hi, I have a very strange situation.
    3 Avid MC on 5.0.3
    1 MediaEngine V5.1.3 4gb Ram 16x1TB (all green on profiler).
    1 Qlogic with the configuration of 1NM, 5 Clients, 4 JBOD.
    2 Mediarray LP 16x500gb( with the correct IBOD to work on 5.1.3).
    When I add 1 Mediarray LP to the Data Drive set all works fine, if I add the second mediarray all the clients cant connect.
    (as soon as I add the drives of the second LP chassis in the Data Drive Set, I cant connect the clients).
    If I Remove the drives of the second chassis from the Data Drive set, all work fine.
    If I remove the drives of the first LP chassis, and add the drives of the second LP chassis to the Data Drive set, all work fine.
    I do this several times for other projects with no issues, but I dont Know what happend this time.
    I re Image the 2 Mediarray LP with no success.
    Somebody can give me an idea?
    Its a good idea re image the MediaEngine? (we are in the middle of a production)
    Thanks in advance
    Regards
    Rob.
    2 Unity 16TB, 2 Archion Synergy 32TB, 2 Lanshare LP 8TB, 2 Mediarray LP 8TB, 1 Lanshare EX 2.88TB,1 DS 10.5, 2 Symphony Nitris DX, 6 MC Nitris DX, 5 Media... [view my complete system specs]
  • Mon, Sep 19 2011 4:45 AM In reply to
    Re: Problem With Mediaengine 5.1.3 & Mediarray LP
    This sounds vaguely like an old bug.  Adding more than 16 drives caused it.  I didn't find anything either in the Avid Knowledge Base or in Google searches though.
    Hopefully, someone remembers it ...
    (wwld)
  • Mon, Sep 19 2011 2:15 PM In reply to
    • Jens Hoppe
    • Joined on Thu, Apr 21 2011
    • Frankfurt, Germany
    • Posts 64
    • Points 755
    Rob,
    could you post more details about the clients trying to connect?
    What are type are your fibre-cards? Might there be ATTO clerity 41es that are not at the minimum of Rev. D (see KB article 348959)?
    Can ether-clients connect? Does your MN engine see all 32 drives in the LP chassis?
    Jens
    MacPro, MBP, Z400, Z420, Z820, MN5, ISIS5000, Interplay... [view my complete system specs]
  • Mon, Sep 19 2011 2:37 PM In reply to
    • RobertoMFS
    • Posts 78
    • Points 1,040
    Hi
    in the Setup Mannager i see the 32 drives in the Data drive set (2x1TB spares & 2x500GB spares). and in the Raw drives I see the other 16x500gb Drives.
    If I add the raw drives to the data drive set, i can connect the clients.
    if I remove the 16x500 gb drives from the Data drive set, and add the other drives work fine, but dont work with the 32x500gb drives.
    The Atto cards are the FC-41ES (i dont know if are rev D, but work fine with only one mediarray LP).
    Very strange thing.
    thanks
    Rob.
  • Mon, Sep 19 2011 5:16 PM In reply to
    • AvidHammer
    • Joined on Mon, Mar 13 2006
    • Los Angeles
    • Posts 170
    • Points 1,925
    I've seen something similar but I'm still unpacking it from my brain.
    What operating system are your clients running?   ...do you have anything else you can try to connect?  (Mac, XP, Vista64, Win7)
    ~Hammer
  • Mon, Sep 19 2011 5:25 PM In reply to
    • RobertoMFS
    • Posts 78
    • Points 1,040
    The clients are z800 & 2x xw8600 on W7.
    Work fine if I use only 1 mediarray Chassis, the second are connected, but not in the Data drive set.
    Thanks in advance.
    REgards
    Rob.
  • Tue, Sep 20 2011 5:31 PM In reply to
    • AvidHammer
    • Los Angeles
    • Posts 170
    • Points 1,925
    And if you add the second chassis to the data drive set, the unity seems to be fine, right?  Data Drive set adds them with no problems, and you can get into administration tool from the Media Engine server?
    The problem is trying to mount workspaces from either group, correct?
    Is there any way you can try connecting an XP system to it?  I had a (somewhat) similar issue where the XP stations could see the newly added drives but the Vista64 stations could not.
    ~Hammer
  • Thu, Sep 22 2011 12:37 AM In reply to
    Do the drives have Avid firmware on them? Can you run ASM on the drives?
  • Fri, Sep 23 2011 9:53 AM In reply to
    • RobertoMFS
    • Posts 78
    • Points 1,040
    PROBLEM SOLVED!!!
    After some days one of the Workstations sometimes cant connect, but connect fine on restart.
    I check the atto configuration, and the connection mode show "PTP Preffered"
    I change this to PTP, and add the 16 x 500GB drives of the second mediarray to the Data drive set and WORKS!
    This atto setting maybe can cause a conflict that make the problem with the mediarray.
    Thanks to all for your coments!
    Regards
    ROb.
  • Fri, Sep 23 2011 4:49 PM In reply to
    • AvidHammer
    • Los Angeles
    • Posts 170
    • Points 1,925
    What's the setting of the ATTO card inside the LP chassis?  PTP or PTP Preferred?
  • Sat, Sep 24 2011 1:04 AM In reply to
    • RobertoMFS
    • Posts 78
    • Points 1,040
    All the Chassis are in PTP, 2 workstations in PTP, and one in PTP preffered.
    I always configure as PTP, I dont kn ow how can be changed.
    As soon as I discover that 1 workstation was wrong I change the configuration, and all works fine.
    TO be honest I never think that 1 workstation can make this strange behavior.
    All days we can learn something...
    Regards
    Rob.
